Discuss Gap between Tiles and the edge of the room in the Canada Tile Advice area at TilersForums.com.
its practice thats makes perfect your guy may be hasent had enough practice.Lot of good work previously done for me.
Room completely empty, so thought it was relatively simplistic job. But hasn't turned out to be.
The advice above has been very thorough, and as a first time poster it is appreciated.
Next time I come to tile, I will attend a course and do it myself.
try a course then you see its not easy what we guys do day in day out did you see any of this guys work earlier?
Your a very forgiving client!
Any tradesman worth his salt would rectify at his own cost.!
Hopefully you end up with a job your happy with at the end of it all
Erm.
Don’t want to pee on your chips but the floor should have a movement joint between the 2 substrates!
It looks from the pic that the full tile is close to the edge of the matting.
Your tiler may have this in hand but I would recommend a cold joint (silicone instead of grout) down that whole join!!
Take some tiles down the tile shop where you got them with the measurements explain your predicament and I'm sure they will find a friendly tiler who will cut them when he has his cutter out on a job . I know I would no problem . As I said before the dimensions without skirting would Be an easy cut . Mountains and molehills spring to mind
Reply to Gap between Tiles and the edge of the room in the Canada Tile Advice area at TilersForums.com
