View the thread, titled "Gap between Tiles and the edge of the room" which is posted in Canada Tile Advice on UK Plumbers Forums.
I don' know why he wants to chisel into to the plaster your skirting I think I read was 20 mm plus the gap easy cut
Hi, just getting to the back end of this job now.
In regards to the area I am covering with slither tile cuts, as these will be covered by skirting and scotia beading, could I bring the level up with self leveller and avoid having to wet cut a bunch of angled 20/30mm tiles?
Erm.
Don’t want to pee on your chips but the floor should have a movement joint between the 2 substrates!
It looks from the pic that the full tile is close to the edge of the matting.
Your tiler may have this in hand but I would recommend a cold joint (Silicon instead of grout) down that whole join!!
Thanks Wolfie.
Which cold joint Silicon do you recommend? My grout is in gunmetal, so I hopefully will be able to get a matching colour.
Take some tiles down the tile shop where you got them with the measurements explain your predicament and I'm sure they will find a friendly tiler who will cut them when he has his cutter out on a job . I know I would no problem . As I said before the dimensions without skirting would Be an easy cut . Mountains and molehills spring to mind
Cheers fella. I got a wet cutter and have sorted it out. Will cover the gap with skirting and scotia beading.
Now just trying to work out how to do the cold joint Silicon.
Reply to the thread, titled "Gap between Tiles and the edge of the room" which is posted in Canada Tile Advice on Electricians Forums.
