Gap between Tiles and the edge of the room
Lot of good work previously done for me.
Room completely empty, so thought it was relatively simplistic job. But hasn't turned out to be.
The advice above has been very thorough, and as a first time poster it is appreciated.
Next time I come to tile, I will attend a course and do it myself.
its practice thats makes perfect your guy may be hasent had enough practice.
try a course then you see its not easy what we guys do day in day out did you see any of this guys work earlier?
Yes Ray, his other work was good.
Issue has been created by not starting in the centre of the room. He layed the first tile in the top left corner.
Then as that wall is slightly bowed, it has caused the tile line to be off.
Will either use scotia beading or a thick skirting board.
Need to cover 40mm where it is at its worse.
Luckily the area in will be most out is covered by kitchen units.
Your a very forgiving client!
Any tradesman worth his salt would rectify at his own cost.!
Hopefully you end up with a job your happy with at the end of it all
I have highlighted the issue with our tiler and the fact scotia beading is going to be needed to hide the fault.
This has gone down like a lead balloon.
He does not believe any real issue exists and that chiselling into the plaster and using slither tile cuts isn't a problem.
Was not what I expecting to hear.
Hi Mr t the cuts got to go in now anyway to sit skirt on. let tiler do it then put bead on yourself if not happy with it. not ideal I know but not much option now.
Featured Threads
