Discuss I am about to go and dig up my SLC - rebag it and return it to Weber! in the UK Tiling Forum area at TilersForums.com.
i use webber all the time .........and imo its spot on, good price, 25kg bag, 30mm depth.
when you mix it use your own judgement, its needs to be like cream, and not like pee.
are you trying to make the floor level or flat?
if your floor isn't level then slc will simply run to the lowest point, the more slc you put down, the more it will fill the lowest points and make the floor level, but this will depend on the size of the floor and how much out of level it is
not as far as i'm aware. it's a fibre reinforced leveller can go up to 50mm in one hit.
Reply to I am about to go and dig up my SLC - rebag it and return it to Weber! in the UK Tiling Forum area at TilersForums.com
