Sand And Cement As Adhesive?
Sand and cement fixing = proper tilers,how many on here can do it ? Remember we can use adhesive but can you fix tiles with s&c
How often do you fix tiles using this method? If it was a situation that I came across on a regular basis then I would learn how to do it but in 12/13 years I've never once found the need to do it. I'm upset now as I always considered myself a proper tiler but obviously I'm not!
you cannot beat s/c fixing out side on paths and patio s .if you need to lift a floor height up 30 to 50mm on concarete .you will not do it faster or cheaper than fixing with s/c an avarage tilers that i worked with would lay and tile 20 m2 a day a top one 30 to 40 m2 a day .
then I was a top.........🙁 was...
assegayer,
bansko,
assegayer,
bansko,
