Sand And Cement As Adhesive?
This is my thought, up to 10/15 years ago, I placed only s & c. Now with tiles present, increasingly less thickness, larger and larger, of course, to have less thick tiles, the cooking is automatically lifted and the flatness is not perfect, poses s & c is no longer suitable. Now with a leveling system it is also able to accommodate a non-planar tile.
After this, I think a young tiler although it is capable of s & c there is nothing wrong, instead think of laying a floor with s & c, might consider to qualify on factors concerning the future of the tile example: thin porcelain and its equipment or systems of that type scluther UK are used a lot.
this is just my thoughts, then every tiler is free to think what he wants, if in previous posts I have expressed adequately only because I thought it was a joke, I thought that pose S & C is no longer considered being outdated .sorry) I do not want to talk about the videos, because that person is not a tiler.
p.s I think I thought too .......😉
just to bring you up to date they fix thin tiles in china and india into s/c all the time .why are the thin tiles you are fixing platness is not perfect ?they should have a tolarance over 600x1200 of less than 1/10 of a mm .only 30% of all tiles fixed in the world are fixed with adhesive 70% in s/c even today .even thin tiles
Last time was at your Ray wasn't those 2 Chinese ladies discussing about the s/c fixing not going well or just checking out the adhesive.
well s/c has its place when you have to tile a floor and they want to fix the kitchen 3 days later but need a 30mm+ plus build up on concarete there no better way some tilers have been tiling for years and have not offered this because they dont know how to but thats not there fault they just never got the chance realy its quite easy to do when i get a bit of time i will do a vid and show just how easy it is and how quick
Ray, it is easy to do I agree. Trouble is building regs don't always allow it as I have found out on the job I am doing later in the week.
40m2 floor to be built up 80mm ish , building control said no, had to find another solution.
why
the understanding of adhesive and how to use it.is a big problem in china .and like the uk some tiles have fear of fixing it just dont want to change
Ray.
Needs insulation underneath of a thickness which would leave the screed to thin. This is over a block and beam floor rather than a concrete base (which would probably have the required insulation already in), but do agree it could/would have been a good and cost effective solution.
Did have a call from a guy about the porcel thin up in the docklands and his guys had had no experience with them, surprised he never got in contact with you.
Ray.
next time ask them for the thermal property of beam and block per mm .then ask them the same for there insalation per mm dont forget to ask also the same of s/c per mm next the tile then ask what is the total we are looking for over all .i think you will here a long silence
they may well have done .but all trades will think the bloke in the shop has not got clue
we have not understood, thin porcelain flatness ok. I mean 600x1200 or 1000x1000 200x1200 etc. 9 / 10mm thickness. honestly I have not find any planar.
as regards china india etc., I believe that there is nothing to learn regarding the laying of tiles.
I repeat, it's just my thought, I may be wrong.
and I can also cambiared mind.
because only the foolish never change mind 😉
assegayer,
bansko,
assegayer,
bansko,
