WetSaw
I've seen a Spanish tiler here using a home made gauge, a triangle of 15mm ply with a handle screwed to it. He just whacked it in the corners as he laid the tiles, seemed to work!
Unless I'm completely loosing my mind still can't see where a 45degee angle will help with a herringbone floor, just cuz the tiles are set at 45 to the room they still have 90 degrees between the tiles...or am I loosing the plot somewhere :|Daves right...90. Degree herringbone is easy....its the 45 one that cuts the mustard. Not the kind of thing you do every day......just thought a straight edge or level you can adjust to 45 would help ..
Proper herringbone should be set at 45. 🙂. Better effect.
Parquet man I see.
Diggy 😉
