Guest viewing limit reached
Advice needed - poor workmanship?
wheres the brick bond gone round the window ....beggars belief that he thinks thats acceptable
Would you mind explaining to me what this is? This is what concerns me about the work, I can only comment on the tiling as I can clearly see that the work is shoddy. I know nothing about electrics, plumbing or building work etc so for all I know it could be hazardous! Very worrying really, especially as I have nothing to show the electrical work has been signed off. I also have no idea what adhesive he used and the quality of the work behind the tiles either. I know though that he has put the floor tiles down onto plywood as that is on the invoice. However having looked into this it seems that was another mistake he has made. Am I right in thinking floor tiles need to go onto aquaboard or something similar?
Pic No 3......above the toilet:thumbsdown:
Agreed, that part is a real eyesore, it's the first thing we noticed actually it is really obvious. Regardless what happens that part of the tiling has to come off anyway as the tiling pattern he has used is not brick effect which is what we asked for. He's done brick effect on 2.5 of the walls and then for some reason changed to a different pattern in that area?
IMO you should write or email original plumber and give him a chance to rectify all areas you are not happy with, wether it be himself or him hiring a tiler to sort. Tell him once this is done and you are happy with standard, payment will be made. Give him an agreed amount of time to rectify and if he has not then you will take in other tradesmen to rectify all works which will be taken off his bill till all works completed to a satisfactory finish. Any monies left over will be forwarded to him and copies of bills to get rectified. If he wants to go to court let him as no chance of him winning and all costs will be him liable. Sub contractors are on him also not you!
This is pretty much what I have written in the letter I've put together today which I will send via recorded delivery tomorrow. We have offered both the opportunity to rectify the work himself as well as to source a different tiler of his choice but he has declined both and suggested we source a tiler ourselves. I've confirmed that in the letter. He is still asking for payment to pay off the subcontractors so I've stated that our contract is with him and not them. What a nightmare situation :-(
Tiling onto a plywood overboarded floor is okay provided it has been fixed correctly minimum thickness of 15mm and of exterior quality, WBP.
Just looked at invoice, he has used 2 sheets of 6mm ply, not sure whether it is outdoor quality, it doesn't say?
outdoor quality or not. 6mm shouldn't be used as it just follows whatever flex is already in the floor. As above, needs to be 15mm minimum.
He should have gone for a more suitable cement board such as Hardie Backer. You "might" be "lucky" and "get away with it" if the subfloor is rigid enough, but its not a professional approach and goes against the British Standards code of practice. Keep your eye's peeled for hairline cracks and loose tiles if the tiles are going to stay down, but the advise would be to rip it up and do it properly.
Anything can look okay from far enough away!
Threads like this always turn into multi trade bashing.
This guy's a crap plumber and a crap tiler.
No way would I even attempt to make good - BIG can of worms and it will never look as it should. So sorry that you have found yourself in this position.
With regard to the payment situation. The Law likes to use the term "reasonable" when to comes to payment and withholding money.
You have what appears to be a useable bathroom, not particularly well finished but at least serviceable to a degree.
From a legal standpoint it is important that you are seen to be reasonable should this eventually go legal.
Withholding the entire payment is not reasonable, however making a part payment being accompanied by a snagging list detailing exactly what needs to be rectified is reasonable. Once this work has been completed then the balance is payable.
The percentage is down to you to figure out and I guess would also be effected by the products supplied. i.e. if the suite was supplied by the plumber then it would be unreasonable not to pay for items supplied as you now have the items. However if this is a labour only situation then I'd be inclined to withhold say 50% or so. Taking this position strengthens your case considerably.
I agree with what you are saying about looking reasonable in front of the court and the fact she has a serviceable bathroom and goods supplied . But I believe the remedial work will cost more than the job value in the first place so the customer is left trying to reclaim that money back from the plumber who wosrt case scenario is a plc or llp and wraps up his business and is trading the next day under a different name.
Karen79,
Time's Ran Out,
Karen79,
Time's Ran Out,
