Discuss Awkward cuts? in the Australia Tiling Forum area at TilersForums.com.
K
kimboslash
i wouldn't recommend grouting as it will be pain in the back if toilet will need to be taken out in the future. as i was replacing cracked toilet and it was time consuming as it took ages to get the grout out. nice cuts btw
Good point well made, when grouting i cant help myself but will keep that in mind for future reference!
David Rowell
Im no expert at tiling but when i do carpentry im often cutting and scribing
Wood to different materials. I guess a chippys way will work in this instance.
Get yourself a a set of large compasses depending on size of tiles your cutting.
Put a pencil in them by what ever means possible aslong as when you do the tip touches
The point when shut.
Now put the point at the base of what your scribing to and the pencil 90 degrees plus a spacer
Thickness less from the tile next to it. Leave them a side for a sec
now get a fresh tile and put the point on the left side and mark a small line onto the tile.
Square that line straight up with a pencil.
Now place that fresh tile on top of the tile to the right.
Open the compasses out so the point is on the shape to be scribed eg toilet base
And pencil on the square line you marked earlier.
Then simply keep it 90 degrees to the toilt base and tile to the right and scribe it. Now you have the perfect scribe.
Explanation is long winded but not in practice.
Hope this helps
Reply to Awkward cuts? in the Australia Tiling Forum area at TilersForums.com
As the replies I got to my previous setting out post were so helpful so I thought I'd ask for...
24K
Alphadock
Hi all my names Lex and I've been a long time lerker but never posted before. I've had loads of...
6K
So I've had my 1200 for a while now and it's done 5-600 cuts, mainly travertine, 610 x 405 x...
26K
Jelthetiler
How do I drill a hole in a steel bath. Or cast iron bath. Instructions on drilling into baths...
16K
Deleted member 1779
These Victorian tiles come on a paper mesh. In most cases the mesh has been doubled up on the...
The Legend; Phil Hobson RIP
Awkward cuts?
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
