Discuss Make your own Oak door bar/ transition strips in the UK Tiling Forum area at TilersForums.com.
tfs
Since joining the forums back in 2007, I have read various posts regarding timber door bars and how to make them etc. I have decided to put together a little step by step ‘how to’ guide on making your own Oak door bars/ transition strips.
I purchased a 3mtr length of 20x120 Oak (PAR), Planed all round. With this I cut a batton at 900mm. I will use this one batton to show you two types of door bar. One door bar will be flush type with a curved profile on each side and the other will be an over lapping door bar which has a curved profile on both side but also has a rebate on one edge to allow the door bar to sit over the tile.
Step 1. , I cut 900mm off the timber.
Step 2. Select bit to router profile on each top edge of timber (this could even be done with a block plane of by sanding a curved edge with sand paper) step4 a.jpg
Step 4. Cut the timber down the length to creat two strips (I used my festool saw for this, you could also use a hand saw or a table saw) step 5a.jpg
Step 5. Select rebate bit to router a rebate on the under side of one strip of timber. Mark the depth using a tile as a guage, take underlayment and adhesive into account. step 5b.jpg (if you don’t have a router you can achieve a decent rebate by passing timber over the table saw a few times adjusting the blade depth and tabl;e fence/guide until you have removed enough timber to form a good rebate) step 5c.jpg step 6b.jpg
Step 6. Once you have finished profiling the timber you will need to prepare it for finishing. I preffer to use 120grit sand paper top sand the timber and after this I go over it again with 240 grit to achieve a good finnish. If you need to fill any imperfections in the timber I recommend Metolux a two part fast setting filler step 7a.jpg .
Step 7. Apply a finishing coat to the timber. I preffer to use Patina. step 7b.jpg Patina is a gel that is used to finnish the decks on boats etc. You could choose to oil the timber instead or any other finnish that you preffer but, I feel that thinks intensifies the grain in the timber and leaves an amazing finnish. step 7c.jpg
Step 8. Install the door bar. This can be donw many ways which include,
pin to timber floor with 16g brads (apply Silicon to underside of door bar to help bond)
Use plug cutter bit to cut out hole half way through timber, screw fix to substra step 4b.jpg te and fill hole with a dowel. (specialesr drill bits will be required for this)
On concrete you can stick down with Silicon or adhesives.
On concrete you can also glue and screw using same method described when using plug cutters.
You can install these bard any way you choose dependi step 7c.jpg ng on the type of finnish you desire. If you don’t need to be subtle when fitting door bar then you could simply just screw/ nail the fixing down. ste8rebatedoorbar.jpg
I hope you find this how to guide usefull, you don’t need specialist tools to make a simple hardwood door bard but if you have them it helps. You will at least need the following; step 8c.jpg
Tape measure
Pencil
Hand saw
Sand paper or electric sander
Nails or screws
Finnishing oli, gel or varnish
Gazzer
so would I but , I just cut of the 900mm peice as this was all that I needed to use for the demonstration at this time.
It is deffo easier and allows you to keep work more consistent doing all profiling at once.
Yep that was my thinking too and this is something I have been meaning to do for a while. I have a router table and all other tools which would make it quite easy to do.
tfs
With one length you would have enough to do a few door ways. For anyone who has the tools it would workout cheaper than buying door bars each time. Especialy, when you struggle to get them with the rebate as the depth of tile and underlayment is usualy deeper than standard trims that you find in most tile shops etc.
Oak looks stunning too!
Reply to Make your own Oak door bar/ transition strips in the UK Tiling Forum area at TilersForums.com
Following on from Bri's thread, 'awkward cuts' I thought it would be good to see what various...
2 3
16K
Spare Tool
11K
Rizzle from the Portizzle
A kind plumber has created a thread (that he's still working on right now) explaining the do's...
8K
Some background first, then my question.... The designer's plans for this bathroom called for a...
MTiler
29K
ScottG13
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
