One stupid naive tiler needs help!
Ok so the guys in the know can answer correctly can we have a run down of products used and in what order please.
Chilli if you have got any T-cut in the back of the car, black stain a spare tile with the said grout and give it a try by rubbing the tile with a tea cloth.
You never know, I can't help beyond that. Good luck!
Not got t-cut but can buy some if it works!
First of all the tiles were covered in a plastic stuff and wax, so we took the plastic stuff off before we layed them, we then got a tile cleaner from Topps tiles called FILA, then we sealed them with the FILA sealant.
Then grouted.
t cut is a mild abrasive and works by cutting the dirty layer off the paint revealing fresh paint which can be polished
im not sure it will work on polished porc
I use wd 40 for cleaning stubborn stains and lifing stains out of worktops
but ive never tried it in this situation
you wont be the first or the last to do this and someone here may well have the solution so hang in there chilli
Chilli if it is surface stain it should come off. However, if it has penetrated you will need a deeper specialist cleaner. I would hold fire for a while longer untill you get further replies. 'Dave' I'm sure will hit the nail on the head.
What ever method you use i would do this on a spare tile.
As for the T Cut i would be careful that the T Cut doesnt penetrate the tile and make matters worse. Never tried it so i dont know but best test on a spare tile 1st.
Sorry to hear your dilemma, did you seal them before fixing edges as well as face? some of this stuff can take in a stain from the joint, if edges are not sealed, causing a picture frame effect. there are some products that could help. Maybe some pics for more detail:thumbsup:
