Guest viewing is limited
can anybody shine some laser or light on something for me?
Thanks Neale. I did look at that but I also looked at the Bosch Professional Tile Laser Complete, I thought it might be handier if someone chose a diamond setup.
hmmmm....will need to ponder this further.
this is a great lasor for setting up your chalk lines saves a lot of time, but the lasor is not very bright and stuggles in bright light you might need the red goggles
As an Amazon Associate we earn from qualifying purchases.
Last night I ended up ordering the one that Neale suggested. It's about 1/4 of the price, so I'll give it a go. Fingers crossed it is ok! It should be here in a couple of days - just in time for my next floor job starting :thumbsup:
Gus, how does this laser work with the problem of the knurled bits on the pole if that is where you want your line to fall? On the stabila you just adjust the heights of the lengths of pole. The Stanley fatmax looks as if on the first section of pole that distance is fixed. I guess you could just place something under the pole?
Hi mate,
The very top has a large sprung area so you can lock each section at different heights so you can mount the laser anywhere. Quite hard to explain but really easy to work around
I sure did. I've not had a chance to use it on a job yet, as this bowling club floor keeps getting postponed. All being well, I'll be priming the floor with Sbr slurry) on Friday and then setting out and tiling on Saturday.
i tried it out in the house and worked a treat, good lasers which are easy enough to see, even during the middle of the day without the need for glasses.
I'll let you know how it performs when setting out, assuming I ever get in to do it!
Which one did you go for?
When I got mine i had a good old play, testing what was level and un-level
